What is granny shifting
and what is double clutching.........
ishcoleobo said::disappoin :disappoin
You've been watching too much fast and the furious....
i believe you are right, but what doesnt make sence (duh, its F&F) is "granny shifting" is actually faster, no?ishcoleobo said::disappoin :disappoin
I would say that "granny shifting".... would be shifting as if you are a grandma. "Double clutching".... i'm pretty sure is when you... 1. Put in the clutch, 2. Shift to neutral, 3. Let out the clutch, 4. Match your RPM's, 5. Shift into the appropriate gear, 6. Match your RPM's again.... and be on your way.
and most expensiveSiver_Cartel said:Slamming gears without the clutch is fastest!![]()
TdotTercel said:i believe you are right, but what doesnt make sence (duh, its F&F) is "granny shifting" is actually faster, no?
you can still match your revs w/out letting the clutch out
HAHA, I agree, but the reason it's good ( I know I'll get some arguments on this one) is the action and the whole racing scene idea.There's a lot of "talk" in Fn'F that doesn't make any sence.
you're right on that oneOstornadoe said:HAHA, I agree, but the reason it's good ( I know I'll get some arguments on this one)
