1 - 5 of 5 Posts
I got a 4efte complete with trans and everything, and I have a few questions. I am going to put it in a 94 Paseo will the axles fit? is the timing belt the same? I just replaced the belt and the tensioners or should I get a stronger belt? Are there any info on getting more power out of it? I am going to get rid of the air to air intercooler and run a water to air intercooler. Any other info about what to watch out for would be great.
Thanks Dana
· N/A bites
Paseo
Yes axles fit if not lsd. No timing belt does not, welcome to JDM101. Lots of info and help on board.tercelonline.com about those swaps. Be prepared as it's a lot faster than you expect. You will need a boost gauge and a good tach.
Discussion Starter · #3 ·
I was able to look over the engine Will the power steering pump and ac compressor swap over, and do I have to make up a harness using a mix of the harness that came with the engine and the one in the car?
Thanks Dana
Discussion Starter · #5 ·
Thanks For the info Trecel GTS, I looked at the wiring guide you posted on DIY some of the wires on my harness is diffrent colours. I guess I can cut open the harness I have in the car and take out the things like the wiper and other wires that have nothing with the engine managment and re-route them with the harness thatcame with the engine. Do you know how I can tell what year the engine is and should I get a shop manual for a Starlet of the year the engine came out of so I can figure out the wires and the vacuum hoses?
Thanks Dana
1 - 5 of 5 Posts
