though ive been using it for about 4000 miles on the new engine now its come to my attention last night the severity of the problem....i had known oil was leaking out of it but not so significantly...i found out last night ther was so little, it stalled the car at an idle up to 2000rpm ! i quickly pulled into a parking lot soon after but not after hearing some very unfriendly grinding/squeeking noise from under the hood most likely the bearings or pistons rubbing. Luckily i had an extra 10W-40 quart of oil in my car.
I went to change out the oil today...nice, thick and black from a 4000 mile engine (2300 of it on the current oil) :sosad:....drained out only about 3/4 of a quart! plus some in the oil filter :ugh3: . I went to check the valve cover when i realized the bolts werent even tightened to 1 N*m!
so i tightened em up to 8 or 9 N*m as specified for the 1mz-fe.....though i have a 3vz-fe i have no other reference.
so thats my story and now im here askin if anyone knows where i can find a cheap one....and NOT a junkyard unless you know of one with an inventory listing...none of those u-pull it places since you'll almost never find a 3vz-fe ther. Anyone have one for sale??? i need it asap, i fixed the crack for now with more epoxy and silicone but that wont last long.
again, this is a 3vz-fe and its the front valve cover....(the one with the oil fill cap on it), thx ahead of time 4 any info
