97 views, no replies...
anybody?
anybody?
never heard about TVS before. here is what wiki says about it:Possibly the Tumble Valve System..
The 2.5L AR engine has them and they're mainly used during cold starts..
I wouldn't say it bendix. to me this noise sounds differently. it kind light grinding/ heavy electrical buzzing sound vs metal grinding bendix (I turned ignition on when car was already running on my older cars few timesYour sure it's not the bendix (starter) grinding? I hear that on a cold morning starting any new Camry.
no. EVAP noise comes from the tank area and only when car is off.EVAP control system?
Ours was sitting in the driveway one day making a weird buzzing noise after it was off. Turns out it's in the manual not to be alarmed if it makes that noise.
Nah. There's a valve up front too.no. EVAP noise comes from the tank area and only when car is off.
didn't know that...Nah. There's a valve up front too.
don't really like this idea...I just chock it up to the oil pressure not coming up fast enough after it starts.
will do.turn on/off the AC compressor and take a listen to see if it's the same kinda noise.
What brand of oil filter and variety/viscosity of oil are you using? The sound is almost like the car's taking it's time building oil pressure and components are rattling until it does. That problem will be worse in the cold with higher viscosity oil - or if the oil is draining out of the filter, as with a anti-drainback valve that's not quite right.Hello guys.
I start noticing a weird noise upon cold start up. It sounds like something is grinding. First goes starter sound and then engine noise together with this grinding noise. Grinding noise goes away withing sec. or so. It is not really loud, but it definitely not engine or starter sound.
It happens only on cold starts when engine is completely cold.
If I start engine, let it run for few minutes, shut it down and restart again, it starts without grinding noise.
Don't remember if car was doing it from beginning, never turned car while I was outside. Few weeks ago when temperature dropped below freezing point, I turned ignition through passenger door to warm up the engine.
After that I begun listening every start up. Every start up same noise. Every morning and every time after work I hear this noise.
No noise if car been driven recently or engine is still warm.
Do you hear anything?
not my car, but sound is identical.
http://www.youtube.com/watch?feature=player_embedded&v=ZK3jEwMZoRc
I owned 2007 2.4 camry with 90K miles -no noise.From what I know the differences between the old 2.4L and the new 2.5L are;
TUmble Valves
Roller rocker instead of bucket tappets
Acoustic Control Induction System (ACIS)
Dual VVT-I opposed to just single VVT-I
That's about it I believe.
Most of the tech in this 'new' engine has been used in the GR series V6 since 2003 LOL
The V6 is way ahead of its time!
