almc2242 said:
Any recommendation on a set of Fuel Injector?
Injectors from a 2JZ-GE. I believe their 360 CC.
One with the 3SGTE MAP Sensor and another with OEM RAV4 MAP sensor?
You can't use your stock MAP sensor. You'll hit fuel cut if you do.
Your stock MAP is only good for 1 bar, which is for n/a engines.
If I leave the OEM fuel injector and ADD a Fuel injector. Will this resolve the fuel starvation?
No.
Seeing that you need to upgrade the MAP sensor and injectors anyways, I would forget about the extra injector.
Upgrade the MAP sensor + injectors. Then use the e-manage to tune your a/f ratio. You'll want to use a wideband O2 to get accurate a/f readings.
I'm not sure if the e-manage has the ability to control ignition timing or not. If it does you'll need to tune that too.
88 LE, thanks you are a great help for me. And for the world. You are recognized in almost all the Toyota Forums. :thumbup:
No prob.
As for being recognized in almost all the Toyota forums, I don't know about that. I only post on a few forums, but mostly here on TN.
