Good evening everyone,
Via efforts of your truely, not that the masses will jump for joy, there is a new aftermarket part coming out for SOHC e-series engines.
I'm happy to announce a new Mod for the 2e/3e/3ee. A mod that should provide both a good gain in Horse Power and torque through out the entire power band, the thinner High Compression Metal (copper) Cylinder Head Gaskets.
After alot research, speaking with experts like Mulberry, different manufartures, and looking at the specs for TRD gaskets available for the 5efe. I'm going to be offering this new mod.
This mod is meant to increase the compression of your engine by reducing the space between block and head. The copper material makes these extremely durable when installed correctly.
Installing the MHG will effectively gain hp & tq, however please note that anyone who uses these will have to run higher octane, possibly preium (93) depending on their set Timing. Though one could run lower octane by retarding timing it comes at the cost of power.
This is meant for anyone who wants to maximize their original or built engine. For a relatively small ammount of money, more on that in a minute.
The Gaskets I'll be offering will be available in the following thicknesses:
.022", .032", and .043" inches or in metric system:
Increase compression sizes of 0.5588 mm, Biggest HP gain, 0.8128mm slight gain and a near stock size of and a stock size of 1.0922mm (this last one is meant for durability and FI applications).
Custom gaskets like these are not cheap costing around $200 to make. However I will be offering quality pieces well at UNDER $100.
How much? Depends on the order size, with larger volume I have more flexibility with the manufacturer, these can offered cheaply because we are spreading the cost of R&D.
Basically what it's looking like at the moment is:
If 6 gaskets get ordered (including my own) cost will be $88.00 USD +shipping.
If 12 gaskets get ordered (including my own) cost will be $82.00 +shipping.
I would greatly appreciate question, comments or concerns. Turn around is two to three weeks once I place an order. 1week to manufacture, 1-2 week to get to me & sent out. Shipping cost should be minimal as this thing is so light.
Any question can go here thought the main discussion is on tercelonline:
http://board.tercelonline.com/viewthread.php?tid=30214
