1 - 7 of 7 Posts
Pochacco Owns Me
yes it'll work but it'll be off. if you have the I4 and want a tach just goto the junk yard find a gen2 camry LE with the tach and put that into your car, that's how i got a tach in my I4 that didn't come with a tach
Still confused...
95 camry coupe v6
yes and as atobe mentioned calibration will be off. i remember someone did that here recently. RPMs were either too low or too high by 900. speedo was also off too. to answer your Q though, yes it will be a simple plug and play.
3s-gte in a Camry?!?
'89 Camry Alltrac
Like the others said - go get the cluster from a 4-cylinder with tach. It will plug right in. You can also simply swap over your speedo/odo assembly and you can keep the correct mileage on your car. Swap all the cluster illumination bulbs to red while you are at it for additional coolness.
-Charlie
Mad Scientist-In-Training
You can find a I4 cluster with tach on Ebay for $20 or less...
I get them all the time...
1 - 7 of 7 Posts
