1 - 3 of 3 Posts
hi,
If I go junkyard to look remove Power Steering Assembly, what year should I remove the part Power Steering Assembly from?? What do I look if I am at the Junkyard? Do I just make sure the same type of engine and the year,too?
what years can I remove the PS assembly if I am at junkyard?
my car is
96 Toyota Camry Le
4cylinder 5sfe
Ninja wrench anywhere
hi,
my car is
96 Toyota Camry Le
4cylinder 5sfe
For mechanical stuff, normally you're OK as long as you keep within the same generation (in your case, Gen3 -- 1992-1996). For PS, there's a number of diffs between the 6-banger and 4-banger, so stick with the 4-banger models. YMMV.
What parts are you getting? Pump? Steering column? Gear Housing?
I want to get Power Steering Gear Assembly from junkyard. So, if I get PS Gear assembly from 92-96. It will fit for my model 96 4 cylinder 5sfe Toyota Camry? Does it matter if I get from 6 cylinder or 4 cylinder?
Thank you, guys!!!
1 - 3 of 3 Posts
