1 - 5 of 5 Posts
I've got a 90 two door tercel, and I was just wondering if there's any way to help the cornering on it. I'm racing it, and they change the track every race so it's never the same, but it's normally mostly left hand turns. It needs to be little stock things, not lowering springs or anything. Did any of them come with sway bars? Any adjustments anywhere? Thanks
My Dixie Wrecked
You can take pretty much the whole suspension off a Paseo, and you should notice an improvement. The front swaybar, and the springs/shocks, were all stiffer than on the tercel.
i am almost certain you will need to drill, tap, and die the mounting holes to the chassis so that the swaybar will mount up. remmember that your year model is before they offered the paseo. your "A" arms will have the holes for the swaybar, but you will need to drill on the underbody for it to mount up.
1 - 5 of 5 Posts
