After searching through all the threads the BFG AT 265/75/16 rub I hear when cornerning into a bump must be the rims I have on. I just have to find out what part is rubbing. Anybody have any idea what part would be rubbing?
My 285's rub the UCA slightly on tight turns. They've been on a while now so I can see a small section of paint rubbing off so I'd check that first. I still have stock wheels so the backspacing doesn't compensate for wider tires. I also have a lift so it's only when turning, but if you don't have a lift then it might be doing the same when you turn AND hit a bump.
