I think you are thinking too much about this.
The fuel system is not designed to hold pressure overnight. If you had a leak down problem it would likely manifest itself as a hard to start problem after the car had been driven then turned off for 10mins-30mins.
The Cold Start Injector Injects extra fuel during a cold start to enrichen the mixture so your engine can fire. If this is not working properly due to a problem with the circuit or a clogged injector then it makes it very difficult to start.
Multiple cranking attempts as you have described would help to over come this.
I would say that it would be appropriate to inspect the operation of the Cold Start Injector and it's circuit.
another thing that could contribute to this type of issue are problems with the fuel pump or circuit.
