1 - 6 of 6 Posts
My ignition key is getting harder and harder to remove after shutting the car off. Is there any preventative things I can do before it gets to where I can't pull it out? Now, I have to jiggle it fairly good to remove it.
2005 Corolla
I would try lock cylinder lubricant, its available at most auto parts stores. Most pf them come in a small tube filled with a graphite type substance.
The lock tumbler is going bad. Mine did that, had to replace the ignition lock. Cost of lock and new programmed keys was a couple hundred bucks!
liquid graphite will solve the problem
1 - 6 of 6 Posts
