I am trying to adjust the brake booster pushrod so it is about a mm away from the piston in the brake master cylinder when inserted. However the brake booster for this car is different than most, in that the the pushrod stays inside the booster, it doesn’t extend outside of the surface like most do. You can see it in the attached photo. I called the parts support and they said you have to push down the back of the booster where it connects to the brake pedal. However this takes a ton of force, you need two hands for this. I don’t see how it’s possible to do this and hold the bolt and turn the nut to adjust the length, which takes an additional two hands. Have you guys done this job? Thanks
