Some oil company reps have admitted privately that "high mileage" is the same formula as regular oil, just with a different label. The AT-205 Reseal that Uncle Scotty hawks can sometimes help slow leaking front and rear main oil seals, but does nothing for regular gaskets like oil pans. The "full synthetic" oils on the market are just hydrocracked dinosaur oil. They're no different on seals than non-synthetic. The very few true synthetic Group V ester-based oils may make older cars leak more, but that's a rare exception. You can use Kirkland or Super Tech synthetic (same oil) and be good for your car and your budget, just don't fall for the extended OCI bullshit. Six months or 5k is the best bet for longest life.I bought a 163k mile 03 Corolla and used high mileage synthetic for about a year. I was new to car maintenance and so I thought it was necessary at this mileage. However upon research, some claim high mileage oil will cause leaks early because it causes seals to swell which will make them wear faster. I was considering switching to regular synthetic but some say that switching from high mileage to regular will cause leaks because the seals will shrink. However all of this is debated and it’s hard to honestly know for sure. In your experiences for cars this model, has there been adverse affects from switching from high mileage oil to non high mileage?
A good friend gave me a 1998 Chevy pickup that he was using high mileage oil. I went back to regular synthetic and a few months later developed a major rear main seal leak. I also have rebuilt automatic transmissions and tearing down a unit that used additive was very obvious. The seals over time turned to loose-fitting mush. I don’t know if there’s any correlation but reading your post has really made me think about it. I will be replacing the rear main seal soon and I will inspect it for those characteristics. I’ll let you know if you want.I have heard it, and come across it now and then from mechanics, online that is. The argument is that the additives in the High Mileage Oil helps seals to swell, this can help older engines that may have started to have very small minor leaks, to get more life out of those seals. The argument is that once you use HM oil and the seals swell, over time they take on the shape of the area they are sealing in their swollen state and will hold that shape. When the HM additives are then later removed from the oil such as switching back to regular oil, the seals will over time shrink back down and the leaks will return or if there were no leaks they may now begin to leak because the seal will now be a bit deformed after it shrinks back down as compared to its shape if it was never swollen in the first place. I am sure there is a video out there someplace where someone has done some testing to see if this is really an issue or not.
But I honestly do not know if the HM oil additives cause a healthy seal to swell any larger than it is new or if the additives just "recondition" old seals that may have over time started to kind of dry out/harden and maybe shrink on their own do to age, maybe the HM oil just kind of rehydrates them to plump them back up to something closer to their new condition rather than making them any larger than they ever were. I think I have seen a video not long ago where they took brand new seals and soaked them over time in 2 oils, one with no conditioning additives and the other in HM oil. At conclusion there was absolutly no change in size between the two, So I think it is more about making old hard dry seals more flexible/soft and back to normal size/tension. If that is the case, if you had no leaks before you should not if you switch back to non-HM oil I would think.
Some reasonable advice, some old wives' tales. "Never mix . ." - nonsense. "High quality brand" - meaningless. API SP and ILSAC GF-6 are the latest industry specs. The color of the bottle and the brand name mean little or nothing.You should never mix Conventional Oil with Hybrid Blend or Synthetic Oils. Use a high quality brand. Watch some of Scotty Kilmer YouTube videos or Car Wizard on YouTube. Most additives are not recommended. If you have a leak, fix it right. Don't overfill oil level. Revving your engine damages it, letting you car engine Idle for more than 5 minutes is bad too. Starting up your car in the Winter is bad because lack of viscosity as oil sits on bottom of the pan and becomes thick, so don't idle too long, get in and go. Some oil additives do work but most do not.
Most of my cars came with no engine in them, so I fully re-did every seal and oil pan silicone when installing the engine, so I use normal non high mileage oil.Just switch to regular synthetic. You shouldn’t have any issues. IMO high mileage for seal reconditioning is BS. Like it works, but if you have a leak, replace the seal.
I know mobil1 is better but it’s just too expensive. Plus I change every 4K miles. If I had longer intervals maybe I’d go with Mobil 1I use only Mobil1 on my cars. 2015 passes 107K with no problem. And 2022 has only, 4650 miles. The difference is that 2022 uses 0-16 oil.
that interval was made with conventional oil in mind. Probably not a bad idea to change it every 5k miles, but it can go longer if you use the right oil.You have to change every 5k miles with synthetic oil. That's what I did on Avalon from the time I got it (new).
In that case I’d just go with a cheaper synthetic oil. Why spend more money only to change it at 5k miles?If you use synthetic oil, Mobil1, you go 5k miles not 10k how the shop says, you will be ok.
Dude it’s not going to make a difference. That’s not protecting your investment. That’s just wasting money and oil for no reason than to make yourself feel better.It's your car, your choice. I'm protecting my investment. Good luck.
Because it can actually last more than 10k miles. But if you’re changing it every 5k miles you’re just wasting money and oil. No other synthetic oil actually advertises 10k intervals. Only Mobil1 does.If it is not going to make a difference, why is one more expensive than the other one?
