1 - 9 of 9 Posts
I need to change the springs/shocks on my '96 Avy (325K+ miles) soon, on all four corners. I'd really prefer to find some good quality "quick struts" but evidently Monroe and KYB are no longer supplying them. However I found these on eBay, made by a company called "Detroit Axle":
https://www.ebay.com/itm/Pair-Front-Strut-Coil-Spring-Assembly-Set-for-1995-1996-Toyota-Avalon/152915787372?fits=Year:1996|Model:Avalon|Make:Toyota&epid=17015249909&hash=item239a7dbe6c:g:Vr0AAOSwNMVajEA3:rk:6:pf:0#rwid
The price is right, they come with a 10-year warranty and the seller has a very good history. I'm thinking they're worth a try but would like to know if anybody here has experience with them.
Sorry don't have an answer but also wanted to know if there any decent quality quick struts. Most seem poor quality and sketchy. Like Gabriel struts anyone try those?
You can maybe take a chance with 1997 Avalon parts as those apparently are still in supply. I doubt there is any difference in suspension between 1996 and 1997 but I can't say for sure.
http://www.monroe.com/en-US/e-catalog/271679
I suggest looking at non-oem aftermarket performance suspension and seeing if they have the same part number for a 1996+ Avalon. If they have the same part number, then a 1997 Avalon Monroe Quick-Strut might fit.
Regarding Monroe QuickStruts
I've replaced struts (both front and rear) on about 4 Gen 1 Avalons. The Monroes work well, but your butt will be dragging after replacing all four in one Saturday afternoon.
As of today, March 4, 2019, the 271-68x family of struts that fit Gen 1 are still sold at retail. I don't believe that Monroe has discontinued them.
Where did you hear that they are discontinued?
Jim Olson
Indianapolis, IN
Hi Jim,
I'd like to use Monroe if possible, but I'm specifically looking for the "Quick Struts" which come preassembled with new springs and mounts. As far as I can tell, most manufacturers have stopped producing them for the first-gen Avalon. I do have a good quality spring compressor but I'd still like to avoid that butt-dragging.
If you know of a source for them, by all means please post a link!
Apparently the 1996 was a "special" year but my bet is the parts are still compatible. Take a chance and get it done or don't and waste time for everyone.
Ah, you might be correct about that.
I've mostly stopped working on 1995-1997 Avalons because there are so many 1998s and 1999s to be had on Craigslist at low price. I buy them and fix them up for my kids.
I recall now that I did do struts on a 1995 Avalon and they were different than the QuickStruts for the 98/99 cars that I am familiar with.
I never met a Gen 1 Avalon older than 140k miles whose struts didn't rattle. I've always wondered who was Toyota's vendor for those.
Been shopping at shox.com since my racing days a decade ago....and using Tokico struts on my '96 about that long with hpaay results. A little stiffer than OE but just fine for both street and spirited driving.
Tokico at shox.com
I would use the Detroit Axle struts all the way around to save money and time. If time and money are no option, I would use KYBs, but then you have to build all four strut assemblies from parts. I installed Gabriels (quick struts in rear, Gabriel shocks plus other after market brand parts in front) last summer and the ride is a little softer than I would like ideally, even if it is generally ok. From having installed KYBs on my Corolla, I know they give a tighter/firmer ride.
I didn't know about these Detroit Axle quick struts last summer. Otherwise I would have used them.
1 - 9 of 9 Posts
