I own a 2018 Camry SE 2.5 litre.
The Camrys CAI inlets are built into the radiator cover. The 2.5 litres inlet is on the passenger side and the 3.5 litre is on the drivers side. Oddly, they could have used the 3.5 litre setup for the 2.5 litre in regards to side.
There is not enough room on the 3.5 litre to take advantage of the second inlet, however, there is on the 2.5 litre.
I tried searching forums/google and seeing if anyone has DIY'd or if Toyota/aftermarket company made a kit that would allow both inlets to function. This seems like a cheaper way to pull in some extra cold air without buying an expensive aftermarket filter kit by simply increasing the amount of air that can be pulled in.Since the second inlet is at the filter box, the short distance and size of the house should be negligible.
Anyone else think about this? Maybe a way to combine the OEM intake assemblies for the 2.5 and 3.5 litre?
Thoughts?
2018 Camry 3.5 Litre Air inlet assembly
2018 Camry 2.5 Litre Air inlet assembly
Thoughts?
