1 - 3 of 3 Posts
I have lost all operation of my hazard and tuen signals. I have checked the fuses (I think) both inside and outside and have found nothing blown. I was wondering what other points in common these may have. The flasher (is there only one? Would it result in the lights being OUT if it failed?)?
Any suggestions from anyone?
thanks
had same problem
found the flasher relay on the drivers side, where the pedals are. Lay down on the floor in the driver's side and look up. You'll see 2 small black relays and one larger one to their right. The larger one is the flasher relay. You can get a replacement at Kragen, part# is EP35, $12.99. I had a hard time pulling mine out, just keep yanking on it and wiggling it around to get it loose, it'll come out eventually.
1 - 3 of 3 Posts
