so this is a long story ill try to make short...
I rebuilt my 22re (first motor i ever rebuilt) and i used a buffing pad to take the old hed gaskey off cuz it was stuck onto the block very good. I may have taken too much off as i put the whole engine together ran great but about 4 days after i blew a head gasket so i took it all apart again and i did a clearance check on my engine block and i have .025 clearance in one spot but not where the head gasket blew. I had .002 where the gasket blew (haynes manual calls for .002 clearance) i did how ever when i rebuilt the engine use the original head studs and before i removed the head i was able to get almost a full turn on each bolt tell i had it back to the correct torque. What my queston is, is if i get new studs and a new head gasket do you think it will work fine or do i have to take my block to a machine shop to get fix and if so do i leave the bottom end together so they can shave the pistons too??
