1 - 9 of 9 Posts
Hey, i just bought an 87 supra with 76000 miles. The head gasket has never been replaced. When do you think it will need to be, whats a good one to use and how much to buy it and get it installed?
Thanks
· 5M-GE
No telling on when it'll go. It might already be starting to go.
There are three certainties in life: death, taxes, and the 7M BHG.
· Got Hardass?
If the car is turbo it is more likely to go at any given time. N/A's are less likely to pop, but it's not unheard of.
Depending on the plans for the car, it's not a half bad idea to just pull the head, get it machined, install a stock head gasket, and use ARP hardware to secure the head. For a stock motor, or nearly stock this will sustain it just fine as long as the work was properly done.
· 5M-GE
agreed.
Discussion Starter · #5 ·
if i do that how much will that cost?
· Got Hardass?
Depends.
Hg- $50-$100
Machining - $100-$400
ARP Hardware - $90
Your time - $Weekend - $Week
If you have a shop do it, I don't have a clue. Your best bet is to call around to shops and Toyota and price all the stuff. Hardware, Stock HG, and such.
· 5M-GE
Toyota will rape you most likely with the labour, and still isn't a guarantee whether they'll do it properly.
· Premium Member
Supra
In fact, they won't get it right, but will pillage your ass for the price...$1200 CDN without machining for a HG, and they will only torque to TSRM spec 56 ft/lbs. Needs to be 70-75 ft/lbs to give you a rest of the engines stock life seal.
DIY or find a trusted local mechanic. Probably no more than 800-1000CDN all in if there's little work to do.
Bob
1 - 9 of 9 Posts
