Header bolts
824 Views 2 Replies 2 Participants Last post by  Bitter
Does anyone know where I can get some replacement Headerbolts for my AFE block? I have been looking at all my usual places, and some not so usual with no luck at all.
1 - 3 of 3 Posts
G
Do you have any to use as a reference? If you do go to a hardware store, if you dont dealer is your best bet.
do not use bolts, use studs. theres a reason they used studs from the factory. not only does it make aligning the gasket with the header worlds easier, studs wont strip the soft aluminum head when you tighten or loosen the header nuts the same way a bolt would ruin the aluminum.
1 - 3 of 3 Posts
