1 - 12 of 12 Posts
Hi Guys ,
As i was changing my headlight bulb i have snapped the bolt on the right hand side of the headlight in drivers side the headlight it's still in place with the other 2 bolts but feels a bit insecure is there a website i can buy the same bolt i have been looking but no luck :(
And also a separate question my passenger side window control don't work but i can control it with the driver side controls will this be a fuse problem or the passenger side console??
I have the corolla 1.6 vvti hatchback 2000
Thanks for your help
Super Moderator
2006 Corolla XRS
Which bolt snapped? The one behind the bumper or on top?
You can remove the one from the opposite side and see if a hardware store can match it up with their stock.
For the window control on the passenger side, make sure you don't have the window lock turned on.
If that is off, then you will need to pull the window switch control and test the connectors in the switch and also test the window regulator.
Hi mate thanks for your reply
it was the one on top of the bumper
I have tested the connectors no sign of life... anymore ideas?
Super Moderator
2006 Corolla XRS
Are we speaking of the connectors to the window switch or to the window regulator?
Super Moderator
2006 Corolla XRS
Which passenger door window doesn't work at the switch? Passenger front or rear? Try swapping the switch from the front to the rear or vice versa if the connector is the same.
If not able to, go to a breaker and get a used switch for that door.
Super Moderator
2006 Corolla XRS
Top bolt, fender side - OEM PN 90119-06768
Front bolt, grille side - OEM PN 90119-06790
Bottom bolt, base of headlight assy - OEM PN 90119-06790
Nut, bumper side - OEM PN 90119-06224
288819
Discussion Starter #9
Amazing man thanks for graph!
It is the passenger door front i got an hatchback so only 3 doors :)
Super Moderator
2006 Corolla XRS
I see. Then you will need to inspect the inside of the switch. The contacts and resistor may have died off. Or, buy another switch.
Super Moderator
2006 Corolla XRS
Do you have a breaker nearby?
1 - 12 of 12 Posts
