I have a 2000 corolla and can't quite figure what to remove to replace the bulbs in my headlights. Does anyone have a diagram of which bolts to remove?
Thanks in advance.
Thanks in advance.
Thanks man!you do not need to remove the headlights
just look behind the headlights, and pull off the rubber cover...and remove headlight harness plug. push on spring retainer that holds the bulb, and release the bulb. For the passenger side it's recommended to remove the battery since there's no space back there.
New cars you never need to remove headlights to change out bulbs...
