1 - 1 of 1 Posts
Hi guys and girls, I’ve got a 83 mx62 Cressida.
My issue is: the headlights were working fine, then one night I flicked the high beams off and the lights went off all together. Then the high beams stayed on. When I got home I discovered that the low beams would only work in a certain position and so would high beams (I took the little screw out of the stalk and moved the stalk about)
Now the low beams only work on the corner parts of the headlight, and high beams on the biggest part of the headlight. Has anyone had this issue? Has a new relay, bulbs and fuses are fine.
I’ve attached a photo to make it more understandable as it is hard to explain. Wanted to get opinions before seeing auto electrician
photo is low beam but high beam light is coming on
1 - 1 of 1 Posts
