I've had a lot of trouble with the lever on the column..it has contacts that are crappy.
Thanks guys, will pull the switch out, clean or replace.:thumbup:Headlight relays should be in the engine bay fuse box.
Most likely your problem is the combination switch on the column.
No problem.Thanks guys, will pull the switch out, clean or replace.:thumbup:
Cheers
Waz
