Cibie, Hella and Marchal all make 6054 headlamps that take H4 bulbs. Both provide the (IMHO) European "E-code pattern light." For a few bucks more, you can even get the version with the "city" lamp for a genuine European look. The pattern from the Cibie is supposed to be slightly superior.
They are expensive, though. Daniel Stern Lighting (
http://www.danielsternlighting.com/home.html )sells them for a bit over $60
each!, and I'm not sure that includes the H4 bulb.
There's a lot of "Diamond Cut" H4/6054 headlamps on eBay that are much lower priced (
http://tinyurl.com/7kday). I have no idea of the quality of the headlamp, but if they're the same crapola the "Diamond Cut" passing lamps were that I bought for my motorcycle through J&P Cycles, I wouldn't waste my time. The "Diamond Cut" passing lamps I bought were cheap toy-like plastic. Based on my experience with the "Diamond Cut" passing lamps, I will
not be buying the 6054 headlamps on eBay or elsewhere.
I
strongly suggest contacting Daniel Stern if you're even in the slightest way interested in upgrading your headlamps, even if it's just replacing a cheap set of Wagner 6054s with some Sylvania Xtravision H6054s. His knowledge of lighting is encyclopedic, and as long as you don't do something stupid like argue with him that blue filters on bulbs make them brighter, he'll be very helpful, even if it doesn't generate any business for him.
Disclaimer: I have no association with Daniel Stern, other than as a twice-satisfied customer, and a 15+ year history of correspondence with him.
HTH,
- Arved
'94 2wd P/U
