1 - 4 of 4 Posts
Greetings from the dark side. I thought I'd check to see if anyone has encountered this problem before I get elbow deep in wires.
My headlights aren't shifting from low to high beam when the switch is activated. The indicator on the dash goes on and off normally, the mechanical part of the switch feels and sounds normal, but the lights don't change. The multifunction switch for mine is 228.00 at Advance Auto, I want to make sure this is my problem before I buy it. Any thoughts on what else it might be?
I would find and check the relay responsible for switching your high\low beams before I bought that part, especially since it's turning the high beam light on and off.
Fuses for these relevant? The owner's manual shows one for each low AND high beam on my '03.
And I wouldn't buy that part new. Get it used on ebay or local used parts yard. I've not read they fail often....actually 1st time I've heard of it. See attached for fuse info.
1 - 4 of 4 Posts
