1 - 12 of 12 Posts
Breakin' necks since '02!
The top screw is for the vertical adjustment and the one in the engine compartment is for horizontal adjustment.
I have to do this myself because after I put in my silverstars I noticed that me left headlight aims lower than my right headlight.
How high should the beam be from the ground, because i'm not sure which headlight is off.
O/T is there an adjustment for the high beams?? (Just outta curiosity)
93 Z24 and 78 Bronco
1993 z24
Camryfanatic said:
Which way do I turn the screw to go up and down and the other screw to go side to side?
you'll see it when you turn them.... i don't even know off hand which does which, just play with them
my screws are stripped or something so they don't do anything, but luckily they're pointed in a decent position
TN Pussy Man
Camry
the best way to see results is by using a drill, then you can watch the light housing moving in whichever direction and you can adjust it accordingly
1 - 12 of 12 Posts
