1 - 8 of 8 Posts
Official TN Toaster
2000 Celica GT-S
I know that the halo projector headlights will fit perfectly, though the LED halos need to have the wires soldered as they have no plugs.
Does anyone here Know any custom headlights that will fit directly into a 1994 corolla. No modifications. I bought these online, they fit but the cars bulbs do not with with the hole on the headlights that i bought, stupid... and the mountings are way off...
http://cgi.ebay.com/ebaymotors/1993-...Q5fAccessories
should have searched here first. Those are european model lights with H bulbs. You probably have 9006/9005. Look for the headlights that don't have a sharp corner at the bottom inside corner. On ours, the corner is rounded
Only GOD Knows
Toyota Corolla
Yea, this is a common mistake. But you can make it work if your interested. Not too much to it really. That's what I have.;)
Only GOD Knows
Toyota Corolla
HELP ME INSTALL!!!!! i was about to return but if you guide me im willing to do it!!!!
please pm me!!
It's in the "master sticky" here is the link. You will see where I had to correct the wiring diagram. Refer to the last wiring diagram I posted. Make sure you read the side note for what you will need to do it.
http://www.toyotanation.com/forum/t67103.html
Also, the side marker lights will be another issue since the socket is different from 194 bulbs. The bubmper lights have a socket that will fit in the new side markers. The easiest is go to a junk yard and cut out a couple.
Let us know how it goes...:smokin:
Saloon Fanatic
Mr2
Your cars don't have drl's (daytime running lights) right? Those run the highs at 1/2 power during the day until you turn on your headlights.
Only GOD Knows
Toyota Corolla
Correct, I'm pretty sure all USDM models came without the DRL's, but what I did was splice the 194 socket with the new headlights and hooked them to my park lights. Here is what comes on when I turn on my park lights.
1 - 8 of 8 Posts
