I have a 2002 Corolla with a 1zzfe engine which had the disappearing oil problem. I pulled the pistons, drilled 4 more holes in each piston, changed the rings, and rod c/s bearings. No more disappearing oil....I think! But now the heater only blows cold air. The fan is working OK at all selections.
I tried venting air out of radiator system by removing the radiator cap, running the engine for five minutes until it was warm but that was no help. The upper hose to the heater core gets hot but lower one doesn't so it seems that something is preventing the hot antifreeze from circulating through the heater core.
There is supposedly an EFI or F-Htr fuse in the fuse box just behind the car's battery. It's a black cube about a quarter inch square with two gold and two silver prongs. What does it control? Does it only control the fan or something else like a solenoid that would allow hot antifreeze to enter the heater core?
Any help would be greatly appreciated!
Jon White
Jon White
