1 - 5 of 5 Posts
99 toyota tacoma 4X
Hi there! I'm a newcomer here. I have a 99 Tacoma 4X4 Xtracab 5 spd, 4 cylinder. I get about 20 mpg max when cruising on the freeway. Previously I put over 300,000 mi. on an 85 SR5 Xtracab 4X4. I was averaging 23-28 mpg with that truck.
The new one has less than 60K miles and it's bone stock except for a nice bed liner. Any suggestions on how to improve the mileage?
I am interested in getting the best possible mileage. I was extremely disappointed when I drove to Portland and back recently. I used the cruise as much as possible and set it to either 58 mph in the 55 zones, or 68 in the 65 zones. I got less than 21 mpg.
I hope that some of you wizards can help me!
thanks in advance!
This Space For Rent
Maybe switching over to synth fluids will help you get better mileage. I switched over to Mobil 1 oil recently and gained about 1-2 MPG. Keep your rig properly tuned and have correct air pressure in your tires will help alot too. Staying within the speed limit will help your mileage as well.
EPA rating for that truck is 19/23, according to Edmunds.
You should be able to do a little better, but probably nowhere near 28.
I wonder what they did to make the gas mileage worse! Bigger engine with more towing capacity?
Cressida nut
91 Pickup (Hilux)2wd
check the usual stuff like air filter, plugs, wires, timing, etc i agree that you oughta do better than 20 mpg. tire pressure can make a huge difference for even 5 psi
Speed Junkie
I'm not sure what your final drive ratio is, but I think those 4x4 4bangers came with 4.10:1 gearing which is very short and puts you at a higher RPM during normal driving. Great for offroad but your fuel economy will suffer.
Edit: I found this chart: http://www.off-road.com/toyota/taco/tech/axle/axlecodes.html
You can look for this code on the driver side door jam. Let us know what you find!
1 - 5 of 5 Posts
