1 - 5 of 5 Posts
03 CAMRY XLE
... There is a dial control, on the dash, near the steering column. The purpose of this knob is to adjust the brightness of the instrument lights. ... It is possible that your dash light knob has been left in the 'full off' position. Try turning the headlight switch on, and rotating the knob adjustment located on the dash panel.
... If this is not what the problem is about, then describe it one more time.
Discussion Starter · #3 ·
no no !
There is a dial control work it.
This bottom logo is not in the light panel at all
Look in sig
no no !
You mean on the gauge cluster (i.e. odometer, speedo, tach?)
If you are taking about a Generation 4 Camry (1997-2001), there was no fog lamp on/off indicator on the cluster. Don't think there was one for the Generation 3 either (1992-1996)...at lease for the USA market. If you did get the factory fogs, they were on a different switch near the cluster rheostat as a drop in panel.
1 - 5 of 5 Posts
