1 - 3 of 3 Posts
SC300
Ok so here is the story. Car started acting up one night after i had to shut it down quick because of a cop. turned it back on and the idle would not come down from 2k. So ever since then i have had idle problems and sputtering problems recently. As of right now car will sometimes idle normal and sometimes at 2k. And when i turn the lights off it sounds like its carbureted but when the lights are on its fine. I think it could be a bad ground and have tried swaping the iacv with no luck of it changing. And also now it will sputter at a constant crusing speed at lower rps but does not have this problem when i am accelerating. please help thanks
Super Moderator
2005 Corolla CE
Definitely sounds like a ground problem.
1 - 3 of 3 Posts
