Back again regarding my 1994 Toyota Camry that was brought in with a bad thermostat/overheating and after fixing it has no power. Mechanic still has the car almost 6 weeks later.
Original thread:
http://www.toyotanation.com/forum/1...4-toyota-camry-bogging-down-acceleration.html
We got the point where he said a line on my ECM was shorted out, so I ordered a used ECM of the exact same model. If anyone is familiar or can comment with how ECMs act in Camry's of around my vintage I would appreciate it. The used computer had codes in it when I got it. Is this normal?
He installed the computer and told me the car was running great/normal. He needed to put the glove box back in etc and disconnected the battery overnight.
The next day the car was back to having no power (bogging down) and poor idle again. Supposedly nothing else changed. The computer is still showing codes for Intake Air Temp Sensor and MAP Sensor which according to him are both working properly.
He mentioned that ECM modules get "used to"/"learn" about the car they are in and even on a car as old as mine sometimes need to be flashed (ie the used ECM remembers the old car it was in) to reset it. Is this true/make sense for ECM's this old?
Should the codes clear themselves or maybe is my used ECM bad?
Any help would be appreciated.
Original thread:
