Ok, got a 1993 Toyota Pickup 22-RE engine (about 40k on it) 5 speed, 201K miles on the truck. I run Synthetic Ams-soil, and replaced the spark plugs a few weeks ago.
First things first. Today I was backing the truck up on some blocks, to work on the fender, and noticed a LOT of white smoke coming out when under load. It also seemed like it wasn't getting much power either.
I've researched on the forums here, and it appears I may have a screwed head gasket, and maybe other problems. :headbang: Some stuff I've noticed:
- Coolant leak, or burning off. I'm having to top off the coolant a couple times a week. Last week, I was TOTALLY empty, and I'd checked it a few days before. Almost overheated on the highway before I noticed it.
- My first cylinder has some issues. I've attached pictures of spark plug 1 (burned) and 2 (clean, for comparison). Seems to be burning oil.
- My last post was on a weird idle pattern I've been noticing, when I step on the brake. Might not have anything to do with this, possibly an idle screw. Anyways, I've also noticed it will sometimes idle rough when first starting, or at a stop (foot off brake or clutch).
- Some weird stuff on the oil cap. Deposits from coolant leaking into the engine maybe? Picture attached.
I'm hoping you guys can help me out. This will definitely be a DIY project for me, I dont have a ton of cash. I've got the Haynes manual, and link to the FSM.
Thanks so much! Let me know what other info you need. :thumbsup:
