1 - 4 of 4 Posts
I created a message a couple of weeks ago about the idle on my car. I decided to clean the Throttle Body but since then the idle will not raise if I turn the A/C on, it will go down instead.
Everything was fine before I cleaned the Idle Control Valve.
Do you think some junk might have got in it and clogged it?
Could somebody put a picture on the website to show where the Idle Control valve is located?
Thanks for your help.
Discussion Starter · #3 ·
Thanks for replying to my message.
I had already looked at that post before and it does not look like this on my car. I do not have that little hole in the throttle body and it does not seem the IAC is located at the same place either.
My car was working fine until I decided to clean the Throttle body for ''preventive maintenance'' . Since then, no boost in idle when I turn the a/c on, fast idle does not last near as long when the car is cold.
This situation is very frustrating. Do you guys still think it can be the IAC? When the A/C is on sometimes I hear the motor click and the car jerks a little bit. It is not very bad but I feel like soemthing's wrong. Would a clogged IAC produce these symptoms?
1 - 4 of 4 Posts
