1 - 3 of 3 Posts
Ok.....wanted to clean the MAF sensor, since the truch has 240,000Km, I can see it, but there is no screw to unscrew it and take it out?......how do I exactly remove the MAF? Usually there should be two little screws that you unscrew, remove the connector and thats that, but there is no screws on this one? Its a 1996 Toyota 4Runner SR5 V6 (3.4)
Vendor
Yours is different. You will have to remove the large air induction tube from the rear of it. Then use a 10mm socket and remove the two bolts on the side that hold it into the airbox. Then pull the whole thing out of the airbox.
You will want to hold the in the same position as it is mounting in the airbox with the square part facing upward. Then spray the electronics parts cleaner into the nose of the torpedo tube. The hot wires are deep inside there.
Gadget
www.URDUSA.com
1 - 3 of 3 Posts
