1 - 20 of 26 Posts
aka TRD_roLLa on CC.com
i got a 1994 corolla w/ 189,000kms on it
3000kms ago, i did my oil change i use mobil 1 10w30
a week ago i checked my oil and it was low.. so i put a bit in (only about 200ml)
today i check the oil level and its LOW so low that its not even on the oil stick anymore! wtf is happening, no leaks to what i can see...
milage on the car is great i got 175kms off of 13L of 87 octance last week...
n e suggestions on what i should do?
thanks in advance
Discussion Starter · #7 · (Edited)
one thing for sure, no oil is coming out of the PCV valve, there's no smell of burn oil or gas or fumes...
fuck, piston rings?:( :(
edit.. wait..
i donno if its the piston rings b/c i still get great milage, no black smoke coming out of my exaust and no gas/oil fumes from the engine bay
Druken Postwhore
AE92GTS
well, another you can check is you Tranny fluid too.....its possible your crank seal be blown or worn.... on the tranny side.
if your tranny oil turned brown, possibly that.
you do drive Auto right mike?
Discussion Starter · #10 ·
ahh
trddragoon (itchy right?)- its Larry btw... lol (actually my bro's name is mike haha) yea its auto =/
ill check my auto tranny fluid asap..
thanks
i dont think im burning oil b/c the smoke isnt blue or black.. and it doesnt stink either
from what i gather your burning oil...
turn your car on and go look at the exhaust fumes if its blue go kiss a shoe, your burning oil.
I really cant gather where else your oil could be going if theres no leak stains or what not.
Discussion Starter · #16 ·
flashmn, i do notice it has been a little moist (as in the dirt around that area is shiney and wet and not dry) on a small top portion of the tranny, like.. its wet, not leaking or anything close though... but i have checked that out.. before it was the tranny fluid b/c it was too full.. but now since it's still moist around that area it could be what ur talking about..
how could i check/confirm its that?
*i have another question..
would i be able to use engine oil additives when im running full synthetic oil?
Resident asshole
Corolla
Well.. does the car drip oil on the ground after a drive? Does it look like its wet all the time, like blackish fluid? take your hand and run it on the bottom of the thermostat housing/side of the block, if you get oil on your hands, its probably that. Then again, is gonna be bad if you really lose alot of oil at a short time, so you should notice.
Discussion Starter · #18 ·
thats the thing, the car doesnt drip nothing, when i run my finger across the bottom of the engine on the righ hand side, there's dirt mixed w/ a bit of oil.. i think its oil...
well 3000kms and it burnt 1/2L of Mobil1
1 - 20 of 26 Posts
