Taillights you can "redout", there is no aftermarket tails, unless you get JDM taillights. As for power, swap is the easiest way to make power, as for bolt ons, intake, exhaust. HKS makes an exhaust for it, go to procarparts.com, or do a search on the net.
As for the intake, Iceman cold air use to be avail, I think they went out of business. I beleive you can use a either a 95 mitsubishi galant or a 92-95 civic intake pipe, and just use a universal cone. Depends on how much you wanna spend, look around on the net, plus there are a few homemade mods that can be done. Good luck.
As for the hood, you might have to look into getting that custom made, my suggestion on that one, is look for an alltrac hood, the scoop will keep the motor a lil more cooler(not drastically different) and at least your one step closer if a swap ever happens to be considered.
