its a nice car
very little rust damage
(although i would like to get some advice on what locations rust the fastest so i can do a check on it)
but anyways, it has been sitting for the past 9 years. ran fine before that
(except a slave cylinder, but that wouldnt affect anything but moving)
i put new points, spark plugs, ignition coil, spark plug wires. to fix the spark problem
the engine isnt seized because i can take off the air filter top and put gas straight into the carb and it will run for a brief second.
:also: when i put gas straight into the carb, it has uneasy motion and like this slight knocking sound. i dont know if that would settle down once it got past start up and into idle but its worth mentioning
i need like a list of things i can check into.
starting with the easiest/cheapest first *please* so if its something easy i dont waste money (i will never waste money on this car anyways since i plan on keeping for a long time 10-15 years)
thanks
thanks
