1 - 3 of 3 Posts
My truck died while driving. I lost spark. The fuel pump works, i changedthe fuel filter, the timing belt is intact, the cap, wires, plugs are new. the cylinders are getting fuel. All fuses check clear. I removed the cap, and the rotr spins when cranked. The ECU is not trowing a CEL.
I have a lifted 93 T100 4x4 3inch body, 3inch suspension, 33's , tweed interior. Any Advice? Is this common for Toyotas? What should I check, and how should I check it.
Thank YOU;
J
Give me somethin to break
05 tundra doublecab
You have a 93 t-1oo,therefore it has the 3.0 v-6.Dont waste your time looking at the well intentioned camry post,buy an ignition igniter.Install the ignitor and your truck will run again.been there!
1 - 3 of 3 Posts
