Help! Tercel cv joint input requested!
946 Views 5 Replies 4 Participants Last post by  dmunson318
I just bought a 1984 Toyota Tercel. It is in good condition with decent mileage. The only thing wrong with it is that it's front right CV joint is going to need replacement soon. I am confident that i will be able to replace it with the help of my mechanic friend, but what i was wondering is if there are any other tercel owners that maybe have at one point in time replaced their own CV joint? I was just curious if anyone ran into any unforseen issues with the installation. I was also wondering if it would be more economical in the long run to replace the whole axle assembly as opposed to just the joint? any input would be great! Thanks for the help!!
1 - 6 of 6 Posts
EL44 Paseo
jdmtrdriderpr said:
I think it is cheaper and better to buy the whole axel assembly. Replacing the axel is something very easy, nothing mayor if you know what you're doing.
joints cost amazingly high compared to the actual shaft. i used to work at a parts store, and we would always laugh when customers came in demanding to have a boot over a shaft. but whatever you wanna do... if you're having a shop install it, just get the whole shaft, as the labor involved on changing a boot takes longer than replacing a shaft. they have to pull it out either way to do either job.
1 - 6 of 6 Posts
