Just finished changing timing belt, alternator belt and power steering belt on my 2002 highlander V6 engine... turned the car on for about a minute and it ran perfectly quiet... then a couple minutes later I turned on again and there was BAD screeching... the screeching was always there, but it did vary a little in intensity...
The power steering goes from pump to crank pulley, the alternator belt goes from alt to compressor to crank... each belt has its own manual tensioner....the guy at dealership told me to tighten belts until I cant twist them more than 1/4-1/2 turns... but maybe he thought I had a serpentine belt... maybe these belts have to be very tight?
could be a bearing too... but I hope not...
Anyone have any ideas of where I should start?
It is loud, so figuring out where it is coming from may be difficult because of the level of noise and the location being difficult to see very well
the alternator belt seems to be hot after running for a minute... but I dont know why it ran great the first time I started...
Thanks for any suggestions!
