1 - 3 of 3 Posts
Well I jsut purchased an 86' 2wd toyota. It has a 32/26 Weber on it and the obvious 22r. Well my first problem is the temp guage isn't working. So I looked into it and the guy had an aftermarket one in so now im not sure where the original is and what color the wire is. Hopefully you guys can help with that. Secondly the electronic choke isn't hooked up and im not sure where and what color this wire is either. Now if anyone knows off the top of their head what the colors are for these and/or the locations that would be great. Oh and if anyone has a link or something for a not confusing wiring diagram for those wires and the routing of the heater hoses in the bay(not hooked up either) it would be greatly appreciated.
Thanks,
Anthony
the elect choke wire is on a 4 wire harness by the battery. It is a black wire with a yellow stripe. The temp gauge wire is on another 4 wire harness also by the battery. It is yellow with a green stripe. Use a 2 1/2 foot piece of wire for each and splice a connector that plugs into the connect like this
then get a terminal for the choke and temp switch like this
for the heater hoses it goes from water pump to the intake, intake to heater core in( one on the left on the firewall), heater core out to heater control valve in( one on top), control valve out to radiator. Let me know and hope this helps
1 - 3 of 3 Posts
