Before deciding to mod your car, you need to think it through. It can be an endless money pit putting a strain on an already sparse cash supply.
Not only is it difficult financially, but it's also hard on the car causing premature failures and more repairs. Often times you also have to use higher quality parts which are more expensive. Not to mention the downtime, towing costs, stress and frustration.
Okay so you're rich and what I've just said above doesn't apply...what about support in the form a good shop with trustworthy and knowledgable ppl to work on your car?
I don't wanna put a damper on your plans- just being realistic. Spend some time doing research. There's tons of info avail if you know where to look. Have a plan and save your money slowly and do things properly. If a supercharger is too ambitious, maybe start with smaller things such as suspension and brakes.
Regardless, planning is the key and hopefully TN can help you along the way :thumbup:
