2007 Corolla S
Hello TN! I'm hoping some of you guys are interested in giving me an education
There used to be an awesome tutorial on 9thgencorolla.com before it went down on the type of wiring setup I'm trying to accomplish. I've seen tutorials that are similar but involve using a switch you need to flip every time you want them on or only when the doors open and close, and most of them are for 10th gen corollas.
Goal:
I want to wire two LED strips in the driver and passenger footwells that turn on either with DRL's OR when I actually flip the car lights on (I would prefer the latter). I don't care if they turn on and off when the doors open and close, I just want them to turn on and off with the lights.
What I Need Help With:
1. Where to tap the wires to make this possible.
2. Do I need fuses, relays, if I install a switch where would I place it?
3. Do I need to create a ground or are the wires I tap into already grounded?
4. Is it possible to overload a set of wires by adding these LED lights?
What I'm Installing:
2 12v LED Strips with their own set of two wires coming out of it and nothing else.
Possibile Option?:
I saw something I thought might work. There is this extra set of wires with a female adapter that don't plug into anything! I know that some of the older corolla's cigarette lighter's had a lit up ring around it and mine does not have that ring so I am assuming this could be the exact two wires I need to make this install possible because if it is the same cable in older versions of this car (earlier 9th gen) then it was wired to light up with DRL's.
One wire is green and the other is white with a black stripe. Which of course I don't know what they mean.
Thanks a lot to everyone who will help me out! Let me know if I need to clarify anything
Goal:
Possibile Option?:
