1 - 5 of 5 Posts
Okay my truck is a 1990 pickup with the 2.4 22re, My problem is that my truck has a miss tell you hit 3000rpm this miss well go away when the motor hits a certain temp and well stay away tell you turn it off and let it sit then is comes back? I have put new plugs and wires but still does this. :headbang:
· YOTA Master
'93 2wd P/U
Diagonosing by a symptom described in text can be difficult.
I'd say if the problem seems like it could be temperature related, I'd expect it to be a fuel problem. If your engine is trying to run lean, before the Oxygen sensor warms up (which can take longer if it is weak) then it would run lean and kind of hesitate and sputter. Once the Oxygen sensor warms up and reports a lean condition then the ecm would correct for the lean condition by adding more fuel smoothing things out.
So check for air/vacuum leaks first. also search the forums to find ways to test O2 sensor output.
Hope this helps.
Victor
· Cressida nut
91 Pickup (Hilux)2wd
miss when cold is what he's describing
could be a temp sensor, though usually they fail the other way round (runs well cold, poor when hot)
could be a vacuum leak that goes away when things expand/get flexible from heat and seal
First thing to check: is the check engine light on. whether it's on or off, check the codes. if you don't know how, get a bit of wire and short terminals T1 to Te1 in the diagnostic connector under the hood near the fuse box. then go in the truck and count the flashes of the check engine light. it'll flash a few times, pause, flash a few times, long pause. it's counting out the digits of a 2 digit number (IE 11-99) write them down and post them up. it'll repeat itself and you'll figure out the pattern.
I have one doing the same thing
Hi mine is doing the same thing put it in shop and they said it was the ignator and it was 700.00 dollars I said no way the truck is not that good.I found one for two hundred and changed did not help.My truck will crank and run badely then die it will rerstart back but will die till it warms up then runs good.
[email protected]
1 - 5 of 5 Posts
