I am driving, but I will do my best. Factory spec is 5 btdc. You will need a paperclip to jump two terminals in the conector box under. The drivers seat. The sticker under the hood will tell you which ones. Timing must be done at 800rpm, so if you don't have a seperate tach, use a spiffy timing light that does. Hook your light pick up to the blue spark plug wire. That's #1 cyl. There are 2 10mm collar bolts.. Loosen, don't remove.. And two Torx / 12mm bolts holding the distributer in place. Loosen those, adjust timing, and tighten everything back up.
A second person is super helpfull cause you can't reach the distributer to adjust, and see the timing marks at the same time. You can try, but concider yourself warned.... Would hate to add third degree burns to an already broken hand
Good luck.
