the door, door panel and the fittings are touching somewhere at a place that is affected by body flexing.
Here is what i would try - Use a little silicone spray at places you suspect the noises are coming from, if noise disapears from that spot you know youve found one of the problem areas. The silicone wont last forever and also it will stink up the inside of your car like sin but it will give you a clue on what to do next and where to do it.
If/when the noises come back, first remove the door panel, carefully, not an easy job so take your time. (online manuals from this site). I'd try silicone sealer or even a caulking gun and caulk from home depot (i think they make it in clear) and use it in between the door and the panel or wherever your silicone spraying told you is a noisy spot. (I wouldnt think you have to go all the way around the door, just at the contact points...).
Before going nuts and squirting caulk on everything, id just do it in a few places experimentally - because right now maybe it is making so much noise you cannot pinpoint where it is all coming from. Replace the door panel temporarily and see what difference it makes in the noise, then go from there.
