Really pulling my hair out with this one.
Rev 1 NA...Tacho stopped working, so here's whats been done:
1. All connectors removed/checked and reconnected.
2. Continuity check the black wire from ignitor to tacho head - OK
3. Feeds and Earths checked at Tacho head - OK
4. Tacho head replaced - NO CHANGE
Basically I dont have a full understanding of the MR2 tacho signalling.
If I put a volt meter on the BLACK wire from Ignitor to Tacho, this read 14.x volt, and drops slightly as the car revs. This reading is also confirmed at the connector on the Tacho....Start the engine and that voltage drops to about 3.85 volt (connector plugged into the binnacle).
I cannot work out where the signalling is initiated, goes through, ends up and then causes the RPM to go up and down.
Totally desperate for help on this one as its really getting me down now, and obviously have to be careful through the gears.
I might add that ALL other electrical items are functioning fine, no problems starting, ticking over or general running. So basically I am open to suggestions PLEASE
Thanks
Graeme
Thanks
Graeme
