1 - 8 of 8 Posts
sleeeeper
'96 Toyota Vienta
Is increasing the Ignition timing really worth it? Does it give a noticible difference in power or response? :confused: I have a 3VZ-FE with Cai and Auto Tranny.
Any tips?
Dealer Tech..not Toyota
plus you may knock under load, or even disel if you go too far...
mixed bag 'o vehicles
how is the timing adjusted? i thought it was all computer controlled?
timing light/or vacuum, by losening a bolt and turning the dizzy.
i think it's electronically adjusted as you drive, but needs a base to start from, or im just thinking of a different car...
The Other White Meat
Holden Apollo
it wont re adjust itself past the base timing. so yorue right :)
my distributor cant be turned, or at least last time i had it off i didnt notice any way for it to be turned because of the bolt that holds it in place isnt slotted.
1 - 8 of 8 Posts
